Home › Forum › Ask A Member › Compression for 1958 Johnson Super Seahorse
- This topic has 15 replies, 7 voices, and was last updated 1 year, 6 months ago by
Sam M..
April 27, 2025 at 9:43 pm #295899
Looks like my post disappeared. Maybe it will reappear or can get retrieved, but in the meantime, here is a shorter (well, maybe not) substitute for it:
John, it looks to me like you’re on the right track! Your motors should certainly be capable of running great with those compression readings. A fuel system cleaning from the gas tank to the carburetor, new gear oil (specifically marked for outboard use) filled from the bottom up, and a new water pump impeller are all good to do before a test run. Your other rebuild kit items are good ones as well, but you shouldn’t need to worry about them until after a test.
Here’s a few tips I hope you’ll find helpful:
When testing an outboard in a barrel (or on a boat), make sure the water level is higher up than the water pump impeller. Normally this means 1-2+ inches above the top of the lower unit. The reason is, if the pump doesn’t self prime and it’s above the water level, it won’t have water to lubricate and/or cool it, so it will overheat and/or wear out, meaning bye bye cooling system.
If you decide to look at the ignition system, there should be a piece of felt rubbing on the cam that pushes on the points. Putting oil on the felt will lubricate this system and is a good idea.
When putting the flywheel back on, be sure to torque it down with a torque wrench to the proper torque specification. This is VERY IMPORTANT so it won’t damage the motor or you by flying off.
While I’m not familiar with the model of boat you mentioned, 35hp seems like a lot for a 12 foot boat, so you might want to double check the hp rating the manufacturer originally suggested.
When shifting gears, go one shift at a time (not forward immediately to reverse – pause in neutral first), and shift in a quick motion. This will keep your gears in good health.
When fueling up, keep in mind more oil is safer than less for these 2-stroke motors.
One final thing:
HAVE FUN!!!
April 27, 2025 at 11:19 pm #295902POOFED ???
April 28, 2025 at 12:57 am #295903POOFED ???
It posted fine. Then I realized one word was italicized in the middle. Didn’t mean to do that, so I pressed the edit button, fixed the italics, then pressed the big blue button that I assumed said Submit and bye bye! Just like nothing was ever there, except at the top of the page it said Sam M. was the most recent contributer to the page, but using different wording. I clicked on that, but it wouldn’t show me that latest post like it normally would.
Kinda disappointing as I liked my wording better in a few sections of that previous version compared to my rewritten one, though I did add a new idea or 2 so I guess it’s not all bad. I should have highlighted it all and pressed CTRL C before reposting. Oops!
April 29, 2025 at 10:52 am #295951Looks like my post disappeared.
Hey Sam –
Your post magically re-appeared! Your original is on page 1 of this thread and your 2nd try is on page 2.
Some things that happen in cyberspace never will be understood! It’s like when an outboard heals itself for no good reason!
April 30, 2025 at 4:08 pm #295991Looks like my post disappeared.
Hey Sam –
Haha! Thanks Dave 😀
