Home › Forum › Ask A Member › compression for 1953 5hp hiawatha
- This topic has 10 replies, 3 voices, and was last updated 10 years, 9 months ago by
chris-p.
February 5, 2016 at 11:12 pm #3574
what should good compression be for 1953 5hp hiawatha? looking at picking one up to replace the power unit that is on mine
dave
gowen miFebruary 5, 2016 at 11:47 pm #31425I’m working on a 53 Hiawatha myself, trying to make one from three
different outboards, as two of the power heads were froze up.
Will be using old pistons, rings, etc. Will be a while before it’s back
together, but will check the compression then.
Mines appeared to originally a dark blue. Are you repainting yours,
and if so, what color blue?
Thanks!Prepare to be boarded!
February 6, 2016 at 12:13 am #31436yup, mine is dark blue and gray with red decals, this is the one i found scuba diving that was still attached to a wooden transom, got it running but found out one of the piston rings were busted, i have been looking all over for color codes and decals but with no luck, going to restore to brand new, may take awhile
dave
February 6, 2016 at 12:16 am #31438i saw one selling on ebay that still had ok paint so i kept the picture to copy it if i could not find decals or paint codes but some how i lost the pic, if you have any pictures of what one should look like that would be great
dave
February 6, 2016 at 2:47 am #31448This place has decals that are very similar design, but
apparently not the same colors used….
http://www.americanoutboard.com/decals/ … watha2.htmPhotos of my very faded Hiawatha before I took it apart…..
(note, paint under rewind cover was quite a bit darker blue)Prepare to be boarded!
February 6, 2016 at 1:28 pm #31466that is PERFECT!!!!! thank you!!! this is my next project for total restoration, just need a power head
dave
February 6, 2016 at 1:30 pm #31467hey buccaneer, can you email those pics? dave_welsch@hotmail.com
thanks dave
February 6, 2016 at 1:48 pm #31468Photos emailed, but you should be able to "right click" on them
and save them to your computer?Prepare to be boarded!
February 6, 2016 at 2:16 pm #31471I have quite a few Gale built 5hp powerheads, haven’t looked at the in a while let me see which one is best.
February 6, 2016 at 4:03 pm #31480check out compression on what you have chris_p
dave
