Home › Forum › Ask A Member › Compression
Viewing 10 posts - 21 through 30 (of 62 total)
  • #245850
      Not necessarily the carb…..If the reeds/check valves are messed up, the crankcase will draw the fuel in, but won’t transfer it to the cylinders due to the loss of crankcase pressure/sealing….
      Remove the carb/or just slide it back on its studs, leave the fuel line on, then pump up the fuel tank primer button….You will see fuel coming out of one side or the other if the carb is messed up…If the carb does not appear to be flooding, then I would remove the intake manifold and have a look at the reeds/rubber check valves…..
      #245854
        Is the gasket on the brass pickup in the center of the carb on and the correct size.
        #245858
        Boonie
          I remembering puting it on. Size I’m not sure. This carb had a needle and seat with no spring. New one had a spring and groove for the spring. Could that possibly be messing things up?
          #245859
            This is the 302984 nozzle gasket Dave is referring to.
            1956-AD-Carb
            #245862
            Boonie
              I will pull it apart tomorrow and try to post a picture. I think we’re on to something. Thanks guys
              Dan
              #245864
              Boonie
                Ok, so pulled the carb back pumped the tank up no gas anywhere leaking. Loosened the gas tank and had past.
                #245865
                Boonie
                  I hate spell check. Tank had pressure.
                  #245866
                  Boonie
                    Is this float correct?
                    04DBF76A-AE9E-488E-B276-7D42D753744B
                    • This reply was modified 5 years, 2 months ago by Mumbles.
                    #245869
                      OK, so it doesn’t seem like the carb is flooding then… You can check the nozzle gasket, but my nickel is that something on the reed plate is messed up….
                      #245872
                      GARY
                        Crankshaft seals?
