Home › Forum › Ask A Member › Compact fuel filters
- This topic has 9 replies, 9 voices, and was last updated 10 years, 1 month ago by
garry-in-michigan.
September 25, 2016 at 4:07 pm #5357
Givng up on ever getting my tanks perfectly clean, I put inline filters on my pea green Elgins. They are small and compact, sintered bronze filters.
They don’t look clogged after about 40 minutes of running, but they will no longer feed enough fuel to keep the engine running.
What do you use in your small motors? I want to keep the filters nearly invisible, so large auto-style filters aren’t suitable, and I have been thinking that the simple molded-mesh screen type won’t stop the small particles so I have not tried them.
Thanks.
September 25, 2016 at 4:43 pm #44707you need to clean the tank. take it to a radiator repair shop to have it cleaned if you don’t want to do it yourself.
September 25, 2016 at 4:46 pm #44708Depending on your boating situation, you could try a boat mounted fuel filter. That way it is large enough to handle all your motors for some extended time. The smaller the filter the less time it will last (if it is doing its job)? You can get filters now down to 10 micron. That won’t even pass water I’m pretty sure, but the filter has to be large enough to trap the water at the bottom so fuel still flows. Just my opinion, I may be wrong.
Dan in TN
September 25, 2016 at 8:07 pm #44709The less gas you have in the tank the lower the head pressure at the filter. Some good filters may not pass fuel, dirty or not, unless there is either sufficient suction as with a fuel pump or with sufficient head pressure as from a full tank. Motorcycles, with their gravity fed systems, run into the exact same scenario. don’t the Elgins also have an in-tank screen?
September 25, 2016 at 10:50 pm #44712Try dipping filter in jewelry cleaner. Not saying it will cure problem but it does a good job with
dingy carburetor parts. The longer in dip the more etching so do not overdo it.
LouisSeptember 25, 2016 at 11:35 pm #44716I have used an in-line type filter they sell for lawn mowers, etc. They are clear and you can see if they are clogged without removing. Sometimes you can tuck them under a cover to hide them. Just put them pointing the right direction.
September 25, 2016 at 11:43 pm #44717September 26, 2016 at 1:15 am #44719quote auldscott:Givng up on ever getting my tanks perfectly clean, I put inline filters on my pea green Elgins. They are small and compact, sintered bronze filters.They don’t look clogged after about 40 minutes of running, but they will no longer feed enough fuel to keep the engine running.
Thanks.
Tank not clean? Screen on tank fuel pickup missing or crudded up? Old hoses or primer bulb shedding particles? Screen on fuel pump inlet fitting OK? What does the carb float bowl look like? Fuel pump diaphragm? If your carbs have drains, do you use them? Usually an inline fliter can be cleared by (gently) blowing compressed air through backwards. but if your system is clean and you are filling the tanks directly from gas station pumps, you should be able to go for years between filter changes. JMO.
September 26, 2016 at 1:54 am #44721September 28, 2016 at 3:02 pm #44845About pump gas …
I have a large funnel with 1000 mesh (100 X 100) copper screen filter soldered at an angle in it. With a film of oil, it WILL filter out water. I use it when ever I fill my tank, be it a separete 4/6 gallon tank or one on the motor. You would be shocked at some of the crap I have found in pump gas. Especially right after the station’s tank has been filled and the junk on the bottom has been stirred up. . . . 😉
