Home › Forum › Ask A Member › coils for tn-26 5hp johnson
- This topic has 12 replies, 4 voices, and was last updated 5 years, 5 months ago by
GARY.
May 23, 2021 at 12:10 pm #238821
GOOD MORNING ITS MAY23/2021….I JUST BECAME A MEMBER AND WAS INTRODUCED TO YOUR FORM
BY T-MIKE VINTAGE MOTOR.I NEED HELP IN FINDING A REPLACEMENT COIL FOR THE TN-26 5HP.
CAN ANYONE ASSIST ME IN BUY ONE OR 2….THANKS FOR YOUR TIME.WILDCARD01May 23, 2021 at 1:21 pm #238822you can go BRP $$$$$ but I always use chineese coils $ and found them to work fine. some disagree but I had no issues
locate the US site as these are in CDN $$$ shipping likely to be lot less… US to US destinations
some chineese sites have free shipping but have longer delivery times… and it seems there are fewer willing to ship free shop around π
May 23, 2021 at 1:29 pm #238824THANKS ALOT FOR THE ANSWER WILL USE IT …THANKS
May 23, 2021 at 1:41 pm #238825the coils that are needed have wide mounting bases….also plug wire are sod to the coil…modern day coils will not work
for the reason there’s no way of rerouting the plug wires to the secondary winding on the modern coilsMay 23, 2021 at 7:14 pm #238837HA! true my bad… common coils started TN27…. which is what I have π
Danny as a new member you have access to down load the bible on oldies
go to MEMBERS ONLY INNER SANCTUM LIBRARY search for Garry’S drop box go all the way down the pictures find the RED JOHNSON manual & just download it to a PDF file then print it out to service your TN and your next oldies
to print such a large manual I used a local print shop… gave them the file on a USB and they printed the book and spring bound it for easyreading
May 24, 2021 at 8:59 am #238853MAY24/2021…..THANKS VERY MUCH FOR THE INFO ON THAT RESOURCE….I NEED ALL THE NEED HELP THAT I CAN GET, AND WILL PUT IT TO GOOD USE.
May 24, 2021 at 10:33 am #238857download the RED johnson manual to proceed & adjust the ignition !!
TN26 have wider laminates and shape as you pointed out !
This reply was modified 5 years, 5 months ago by
JACQUES.
May 24, 2021 at 10:52 am #238859GARRY I DOWN LOADED THE MANUAL…THINKS. WHAT I NEED IS TO BUY A COILS OR A LEAST ONE…
ONE COIL IS BAD.WOULD YOU BY CHANCE KNOW OF SOMEONE WHO MAY HAVE ONE FOR SELL OR
A COMPANY THAT MAY HAVE ONE FOR SELL.THANKS.
BY THE WAY THE MANUAL IS VERY HELPFUL,JUST WHAT I NEEDED TO START ON THIS PROJECT.May 24, 2021 at 11:51 am #238864May 24, 2021 at 2:18 pm #238869Sorry about the caps…..I know they are the ones I’d like to know where I may buy some?
