Home › Forum › Ask A Member › coil
  • #299090
    David C
      working on a Johnson 1946 2.5 HD25 thats been in attic for 50 years. It has a bad coil and im wondering if anyone out there has found one to fit the motors armature as it is very short as the old coil is only 1 1/8 inches  long. Thanks Dave R
      #299091
      RICHARD A. WHITE
        Define bad coil, those generally are good, most often the points need attention, and be cautious of the points, they are tricky to work on. I have the ring to reset the coil back to its original position
        classicomctools@gmail.com
        #299108
          Johnson Outboard Motor Service and Repair Manual # 302231 Tenth Edition covers all Models 1922-1964 .pdf download
          see JOHNSON service manual for servicing HD series
          20$   600 + pages covering oldies
          http://search.homepage-web.com/?src=omnibox&partner=hp&q=https%3A%2F%2Fwatercraftmanuals.com%2Foutboard%2Fjohnson%2Fjohnson-302231.htm
          #299125
            From my experience they had two windings, primary & secondary windings. They are different from later coils having a ground wire from each coil if that helps bond both.
            #299127
              These are the grounds for testing this coin. There is no substitute for this coil that I know of. Be careful handling it as the points where the wires attach will become loose if the wires are moved to much.
              #299141
              CHUCK
                Is there  “Where Used” data for this coil?  Which models used it?
                #299172
                GARY
                  From Johnson common parts list:
