Home › Forum › Ask A Member › Coating a float
- This topic has 6 replies, 6 voices, and was last updated 2 years, 9 months ago by
ROBERT LAFAYETTE.
January 19, 2024 at 12:22 pm #284128
Is super glue or model airplane glue still the preferred product to coat a float? I haven’t done one in years and didn’t know if there was a better product. Thanx in advance.
January 19, 2024 at 12:51 pm #284129Super glue will work but it makes the float heavier. Model airplane paint /dope is best but avoid the modern Urethane dope as it is not fully fuel proof. More good info on the subject
at pochefamily.org/outboard. But note that the ad there for my new leather primer seals and instructions is very old. New price for the last few years is $10.00 US cash.
January 19, 2024 at 1:11 pm #284130I am surprise about super glue making a float heavier.
the gel version may…add some minute heaviness but the liquid like water spuperglue should not impact the weight much.
In any event sanding off the original cracked coating would alliviate the problem and any expected weight gain should not cause any problems jmho.
the new floats seem to work ok and those round ones in TN,s can be replaced with a Mercury float with some slight modifications
CAUTION: when applying SG use extra ventilation . the fumes are very aggressive on the eyes, lungs, tonsils
January 19, 2024 at 2:04 pm #284131Having used both SIG model airplane dope and super glue, my preference is super glue. As Lloyd mentioned, not all of the model airplane dope is fully “fuel proof”. The SIG brand is good but getting hard to find and is pricey. Once opened, the remainder tends to harden in the bottle and ends up being wasted.
The “Original Super Glue” comes in tiny twin packages at the local dollar store. You can coat any float for around 50 cents or less. There is virtually no waste, and it works. I had a float in a pressure tank immersed in fuel mix for a couple of months and when I took it apart the super glue finish showed no degradation. 2-3 light coats with a disposable brush works well.
It is very important to give whatever sealant used plenty of time to cure before exposure to the harsh effects of gasoline. Some expose the coated float to gas the next day after coating it, then complain that the sealant is no good. A week or more to cure is much better.
Improvise-Adapt-Overcome
January 20, 2024 at 9:23 am #284151This float was in a Sea King GG8971A/ Gale 12D15. Is there a replacement float for it? If so does anyone have a part number? Thanx in advance.
January 20, 2024 at 12:12 pm #284154I believe the original part number was 375919 now changed to 396514.
"Every time you remove a broken or seized bolt an angel gets his wings."January 24, 2024 at 12:13 pm #284280I use Bob Smith CA or super glue available at any good hobby shop.
