Home › Forum › Ask A Member › Clinton 5.5 hp Mdl. K-505 How do you service the gear case? No Drain Plugs.
- This topic has 8 replies, 3 voices, and was last updated 6 days, 21 hours ago by
Kent Cochran.
October 31, 2026 at 1:54 pm #330764
I can send pics if needed. I have removed the gear case from motor.
I am als0i in the process of finding a water pump impeller.
Thanks, Kent
Kent Cochran
1949 10 hp Johnson QD-10
1951 5 hp Johnson TN-27
1952 10 hp Johnson QD-13
1956 7.5 hp Evinrude 7520
1957 7.5 hp Evinrude 7522October 31, 2026 at 3:56 pm #330768Here are some pics.
Kent Cochran
1957 7.5 hp Evinrude 7522October 31, 2026 at 8:01 pm #330798There is no drain plug. The cap behind the propeller has to be removed.
October 31, 2026 at 8:07 pm #330800October 31, 2026 at 10:08 pm #330815November 1, 2026 at 1:16 am #330824Question answered.
I will repack with grease while I am searching for a water pump impeller.
Thanks, EveryoneKent Cochran
1957 7.5 hp Evinrude 7522November 1, 2026 at 9:55 am #330833I realize that your motor is a Clinton and that what I am talking about here applies to an Elgin…..but your Clinton impeller looks pretty similiar so I thought I’d mention it.
A few years back I had an Elgin 5HP that needed an impeller that was pretty much impossible to find. Brian Wilcox (a Member who makes impellers) suggested that I use two Mercury 47-89981 impellers stacked. I tried it….and it worked! I had to drill the driveshaft for a second pin. There are a couple of Mercury impellers similar to this one that differ by the inner diameter. You could measure your driveshaft to see which one would work.
Here’s a couple of pics…..
November 1, 2026 at 10:13 am #330840Or…..you could just buy the correct one …..
November 1, 2026 at 10:27 am #330842Thanks, Every for all the help and info. I have the one from discount marine saved in my favorites on eBay. Will be ordering this one. It is nice to know that the Mercury impellers would also work.
I also checked the gear case grease by following the manual’s instructions.Thanks, Kent
Kent Cochran
1957 7.5 hp Evinrude 7522 -
