Home › Forum › Ask A Member › Cleaning Folding Evinrude/Johnson Case
- This topic has 8 replies, 7 voices, and was last updated 11 years ago by
jw-in-dixie.
October 27, 2015 at 9:01 pm #2863
I just picked up a couple of cases for folding 3HP Evinrudes/Johnsons, the plastic ones from the mid-to-late 60s. They have the usual amount of dirt and grime on them, along with some residue from long forgotten stickers. Any suggestions for how to clean these up without removing/affecting the paint?
Thanks.
October 27, 2015 at 9:10 pm #26155I’ve never seen one, but are they painted, or is it gel coat over fiberglass? If I knew this, the sailer in me would know what to do!
October 27, 2015 at 9:23 pm #26157Hot soap and water (laundry or dish detergent) should remove the oily grime. Goof Off is great for removing old sticky residue and other stuff and shouldn’t harm the paint.
http://www.homedepot.ca/product/goof-of … 3ml/977100
October 28, 2015 at 12:30 am #26165You bought those at Suter’s didn’t you? You got the best two cases. I had to settle for the third case. Dish soap and water or blue Easy Off oven cleaner do a great job on grease and oil. Goof Off is excellent for stickers. I use it all time.
Wayne
October 28, 2015 at 1:19 am #26166I believe these are ABS plastic cases. In which case you can use most anything to clean them so long as it isn’t a hydrocarbon, or an organic solvent (acetone, toluene, xylene, etc)
My personal favorite is something ammonia based.If the color has yellowed, I’ve got a pretty slick solution for that.
For what it’s worth, I wouldn’t use the cases as a carrying case. That plastic fatigues pretty badly with time and UV exposure.
October 28, 2015 at 3:28 pm #26194quote wbeaton:You bought those at Suter’s didn’t you? You got the best two cases. I had to settle for the third case. Dish soap and water or blue Easy Off oven cleaner do a great job on grease and oil. Goof Off is excellent for stickers. I use it all time.Yep, I did. 😳
If it’s any consolation, I have been looking for two cases for about 4 years, when I acquired two folding motors………
October 28, 2015 at 3:29 pm #26195Thanks for the tips, guys!!! I’ll try to remember to take some before and after pictures.
October 28, 2015 at 3:38 pm #26196I have fantastic luck using Zep Orange Cleaner. It is terrific for removing heavy grease build up and ground in dirt and it has never damaged any surfaces I have used it on. I have used it on a number of vintage motors with original paint and it cuts right through the built up grease and the oily exhaust stains. It so tough that it is a great oven cleaner, too.
Available at Home Depot and Canadian Tire in Canada. I am quite sure that Home Depot in the US carries it, too. I DO NOT work for Zep, home Depot, or Canadian Tire, by the way 😆
http://www.zepcommercial.com/product/He … -Degreaser
October 28, 2015 at 4:02 pm #26197I frequently use "LA’s Totally Awesome". Dollar General and probably all such stores have it in a 16 oz spray bottle for $1. Also have a larger pour bottle for $3. No acid, ammonia or bleach, and non-flammable. We buy the large bottles and pour it into a pump sprayer for our engines. Spray, let sit for a few minutes, pressure wash. Does a great job. Not sure about decal compatibility – be careful. Cheers, JW in Dixie
