Home › Forum › Ask A Member › Cleaner / Solvent for South Bend Gas Tanks
- This topic has 5 replies, 4 voices, and was last updated 3 years, 3 months ago by
T….in Wisconsin.
July 30, 2023 at 7:31 am #278656
I have a couple “A” tanks that need to be cleaned out. What products or methods will help to remove the dried oil/gas and scale.
Appreciate any and all advise.
July 30, 2023 at 10:05 am #278657I have found no “magic cure”, but I usually get them cleaned out
using mineral spirits, acetone, lacquer thinner, or whatever I have
on hand, usually trying the least “nasty” first, but lots of “shaking”
off and on over a few days, having a large handful of abrasives
in the tank, such as small wood screws, etc., seems to do the trick.
I’m looking for some kind of small abrasive “rocks” of some kind
that would work better, so I’m open to suggestions on that front as well.Prepare to be boarded!
July 30, 2023 at 10:22 am #278658I’ve found that denatured alcohol works very well at cleaning gas and oil sludge/varnish. Evaporust works great at removing rust deposits.
"Every time you remove a broken or seized bolt an angel gets his wings."1 user thanked author for this post.
July 30, 2023 at 10:23 am #278659If you have a good decal on the tank, then be careful of what you use. I use a small length of chain as my “inside the tank” abrasive. I have used Super Clean and my “heavy duty” cleanser. Be careful with that stuff as it can ruin a decal with just a small drop of the stuff. Super clean works as well but is not as powerful as Super Clean. I have also used E-85 gasoline in the tank. It does work. I let it sit overnight and come back to it in the morning, shaking the tank. With the piece of chain, you are sure to get it all out of the tank where with nuts, screws and other loose stuff, you might not be able to get all of them out. Count how many goes in and how many comes out. Now with the E-85, make sure you are outside when using this product. Anything that is flammable should be used out in the open air. Wash out the inside of the tank with warm soapy water and let dry.
Good Luck,
Rick
July 30, 2023 at 10:26 am #278660I started with laquer thinner and it removed some of the residue….ways to go yet.
July 30, 2023 at 10:29 am #278661I like the chain idea I’ll give that a try.
Thanks
