Home › Forum › Ask A Member › Clarke Troller Wiring Questions
  • #3604
    kevinrude
      There are 2 single wires (labelled A and B) and 1 wire pair (labelled C1 and C2). See diagram and pictures below.
      I have A figured out; that’s just regular spark plug wire.
      Is there any requirements on what type of wire I should be using for B (coil to condenser)?
      Same question for C1 and C2 (battery to coil), any particular size, kind?
      Also, do I have the battery hooked up properly in the diagram? Positive to coil, negative to ground?
      Thanks!
      #31691
        Your diagram is missing the points.
        #31697
        kevinrude
          quote Tubs:
          Hmmmmmmmmmmm.
          OK, I will take a closer look tonight and redo my sketch.
          Thanks.
          #31722
          kevinrude
            Here is a picture of T2’s Clarke Troller (I must have downloaded the pictures when he posted them at some point). You can see the wire attached to the condenser, which is then connected to the points. So, my diagram could have been better. Hopefully this picture helps.
