Home › Forum › Ask A Member › Chrysler 3.6
  • #5488
    steeleman
      Does anyone know where to find an impeller for one of these? I have the opportunity to purchase a running one, but im sure it will need a new impeller, if not now, soon.
      Thanks in advance
      #45786
        I found two of them doing a Google search but I’m sure there’s more of them out there. P/N F390065 or FA390065.
        $25 here:
        http://www.nicksoutboardmarine.com/cf-t … -kits.html
        $77.50 here:
        http://www.chrysleroutboards.com/water_pump_kits.htm
        #45788
        steeleman
          Thank you!
          See what you can do if you think:) I just know they are not on marine engine, so I figured they would be impossible to find.
          So, what is the point of even having a pump on this engine if the power head is air cooled?
          #45790
          fisherman6
            The water pump cools the exhaust housing.
            -Ben
            OldJohnnyRude on YouTube
            #45791
              Ben,
              If you know anyone who will help you match an OMC impeller that would fix you up. Is it a bladed or hockey puc type?
              #45793
              fisherman6
                Jeff,
                The original poster is SteeleMan and he is asking about the impeller. This is a flexible vane type impeller in this motor. If there is an OMC impeller that will substitute into a Chrysler outboard Ben Dittmar would be my first go to. I’m sure there are others that know as well, but he is the chrysleroutboarddude. 😉
                -Ben
                #45804
                  Are you sure it even has an impeller? Some motors have a ram tube that the prop forces water up through. Look at the underwater exhaust outlet. Does it have a pipe sticking out and curving forward? If so, no impeller.
                  #45811
                    Your 3.6 should have this hump in the housing for the water pump.
                    The earlier 3.5 Elgin/West Bend based motors are smooth in this area and instead will have a water pickup tube behind the prop.
                    #45818
                      Good info, I did not know about that hump.
