Home › Forum › Ask A Member › Chris Craft Challenger 5hp
  • #4584
      Is there an OMC or other impeller that will fit, or can be made to fit
      in a Chris Craft Challenger 5hp? I believe one place sells them, but
      I’m not sure for how much yet. Just trying to see if they’re more
      options.
      It’s a six vane impeller, 7/16" thick (.437)
      Diameter to ends of vanes is about 1-11/16"
      Shaft size is .550 OD
      3/32" keyway
      Thanks!
      mercuryman
        You could modify a Seirra 18-3000 Dia. =1.7 " thick .8 inch shaft = .5 "
        #38927
        baron0418
          I make them, I need your old one and $25 Brian Wilcox in Michigan 810-794-7685 Baron0418@att.net
          #38928
            Thanks for your help and replies. Will take them under consideration!
            20mercman
              Just a quick note, Brian made a really nice pump for my Corsair 5hp last fall. Worked great!
              Steve
