Home › Forum › Ask A Member › Checkup for good running motors
- This topic has 9 replies, 5 voices, and was last updated 11 years, 6 months ago by
Tubs.
May 9, 2015 at 10:33 am #1438
I have a few old motors (1930 vintage) that I was able to get running with a good cleaning of fuel system and some ignition work.They run great in a barrel.Should I go ahead and check pistons etc.just to be on safe side or not mess with a good thing and start using them?
May 9, 2015 at 12:21 pm #15556I think you already answered your own question. THEY RUN GREAT. I would lubricate everything that moves or slides and lubricate lower unit and give it a go. Bill,
May 9, 2015 at 1:42 pm #15563I agree with Bill, I did that with a Johnson A-50 last year seems to run pretty good on the boat too. I decided was worth a try and am going to try the same thing on a K-50 that wandered in. If you were going to be running them a lot day after day then might be worth tearing them down but for an occasional run think I would risk it.
DougDoug
turned off?May 9, 2015 at 2:12 pm #15567Coincidentally,the two I most want to run are anA50 and a KA38.Both have good original paint and I didn’t want to mess it up.I read a previous post about the aluminum "spark arresters" in the A50 getting eaten and got concerned.I’m pretty sure those are fuel atomizers on the intake ports.
May 9, 2015 at 2:43 pm #15573Don’t forget, the KA 38 requires 8:1 fuel mix!
May 9, 2015 at 2:58 pm #15574I saw that.The first time I saw it I thought it was a typo.I’ve been doing that ratio withTC-W30 for tank tests,is that OK for longer use ?
May 9, 2015 at 3:34 pm #15578The KA has a large rotary valve with two sealing rings on the crank so that is probably why it needs the heavy oil mix. I wouldn’t change it as they don’t make these parts any more.
May 9, 2015 at 3:41 pm #15580So the TW-C3 2cycle oil is ok?What do you use in yours?AND thank you for all the info.
May 9, 2015 at 11:44 pm #15626the standard tc-w3 outboard oil is what I have been using,the A50 I ran at 16:1 will have to check and see what it should run. Last time out wind kicked up @ 20-25 it just pushed on through it on a 14′ boat pretty pleased.
Doug
turned off?May 10, 2015 at 12:20 pm #15651Sent you a PM.
Check your messages
top right of this page.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
