Home › Forum › Ask A Member › Checking motors
- This topic has 7 replies, 6 voices, and was last updated 3 years, 5 months ago by
Marcus.
May 14, 2023 at 11:29 am #276194
The pictured boat comes with 2 1960 Evenrude 35520 40 hp motors with unknown history. Said to have run 3-5 years ago . The windshield might fit my 58 CRESTILNER BUCCANEER 15 SPEEDSTER, also has nice bow and stern light and period controls. What look for on motors and is it safe to turn over motors out of water to check compression $300- 375 for boat, trailer and motors. Ant help would be appreciated. thanks Marcus Westbrook a new member of Peuget Sound Chapter
Westbrook
May 14, 2023 at 3:58 pm #276203Cranking it over dry may damage the water pump impeller. But it probably needs replacing after 5 years anyway.
May 14, 2023 at 7:55 pm #276212boat and engine look clean …indicating care… if the comp is ok I would go for it. but… it may be my eyes…check transom…seems bent out of shape (round in the middle ??? …make certain it is sound or look at it as a long term fix project .
transom can be rebuilt and reglassed. lots of utubes
see book RUNABOUT RESTORATION… .good book to guide you .
trailer looks solid …. probably needs new bearings… easy fix ….engine wise just be prepared to buy lots of fuel 🙂 Common magneto… easy to service
1960 Evinrude 35520 40 hp Outboard Motor Parts (marineengine.com)
it is a 1960 but the johnson red book can help you along to service the engine .
MEMBERS ONLY tab
INNER SANCTUM
LIBRARY
Find ” Garry Spencer’S drop box” down the list
go down to the RED BOOK picture click & download… print locally 400 + pages of good stuff to know. ignition carb gc etc…
May 14, 2023 at 7:57 pm #276214Marcus,
300 to 375 would be a good deal on the windshield only. I paid 45o plus 125 shipping for a custom windshield for my old Cherokee runabout.
Good luck! hope it works out.
Sincerely,
Doug
May 14, 2023 at 9:14 pm #276220You might open the drain plug on the gearcase and see what comes out – dirty oil, water, chocolate milkshake (water and oil mix), rust, maybe no oil at all. If the gear oil looks totally clean and fresh, it might be a sign there’s a problem they are trying to hide by filling it up to make it look good.
"Every time you remove a broken or seized bolt an angel gets his wings."May 15, 2023 at 7:59 am #276227First thing I’d ask is ,do boat and trailer have valid titles ?
May 15, 2023 at 8:39 am #276229thanks for info will take a large bucket with me to fill with H2O, will replace impeller anyway if I buy it.
Westbrook
May 15, 2023 at 8:45 am #276230Pretty much just needing the parts from boat and will have a free hull for someone thats interested. Trailer is roadable and both have titles. Thanks for reply
Westbrook
