Home › Forum › Ask A Member › Champion Jl-15 spark plugs?
- This topic has 4 replies, 3 voices, and was last updated 1 year, 4 months ago by
Buccaneer.
June 19, 2025 at 8:18 am #297432
The old Evinrude spark plug data shows that my 1937 Evinrude 4209
uses Champion Jl-15 spark plugs.
I’ve never heard of those, and I find no used or NOS photos of one.
One reference suggest that the plug number may be J “L” -15, and not J “1” -15,
and that the more modern replacement would be a Champion D-14.Not sure of the “shortest” 18 mm, “mid heat range” plug readily available is, ???
but it would be nice to have a stash of them.Prepare to be boarded!
June 19, 2025 at 10:42 am #297450Is it a JI-15? (Letter “I”). The Champion site below calls the JI-15 a #514 in their new numbering system.
https://www.championautoparts.com/find-my-part/Part-Number-Results.html?part=JI-15
And below is the plug – note at this link, scroll down and they also call it a D-14:
https://www.drivparts.com/part-details.html?brand_code=BBKH&part_number=514&part_name=%7B2%7D
June 19, 2025 at 11:43 am #297451Is it a JI-15? (Letter “I”). The Champion site below calls the JI-15 a #514 in their new numbering system.
The number on the website for the champion version of the Ji-15 is 514, not 847. 847 was the number for a replacement for the J-8J which was discussed in the forum I started. The D-14 seems to have the same champion part number as the Ji-15 on the champion website. The D-14 has the right thread size and gap, but it is a bit cold at a rating of 14. If you can find a hotter plug, you might be able to prevent excess carbon buildup.
June 19, 2025 at 12:57 pm #297452The number on the website for the champion version of the Ji-15 is 514, not 847. 847 was the number for a replacement for the J-8J which was discussed in the forum I started.
Thanks for pointing out my mistake – I corrected my post. The links I posted are correct.
For a hotter plug, there is a D-16,which I have used in the past to replace Champion #7 plugs on post-war Champion outboard motors. Probably new number for the D-16 too!
June 19, 2025 at 5:37 pm #297460Thanks. I test ran the motor today with some medium heat range AC plugs
I had, as they were the shortest I could find, so as not to be an issue
with the front cowl / cover.Prepare to be boarded!
