Home › Forum › Ask A Member › Champion 849 plug
  • #8371
    mercuryman
      Has anyone tied these 849 (Cj6) plugs. If you need a short plug they may be the one to use.
      #65636
        I used some in a 1940 Johnson DT-10, as the spark plug
        cover would ground out the longer plugs when it’s
        installed. Only ran it in a while in a test barrel, but
        seemed okay.
        Am curious if they’re the same heat range in J6C’s?
        fisherman6
          I have a set of 4 of them in my 1949 Zephyr. The longer plugs that were in it were grounding out on the cover. After switching them it seems to be doing fine. I have not run it very much at all, but enough to get it to temperature and idle it down and see that the grounding issue was gone.
          -Ben
          OldJohnnyRude on YouTube
