Home › Forum › Ask A Member › Champion 4K spark plug question
  • #4907
    redpackman
      I have a Champion 4K 7.9 hp engine from ’48-49. Runs pretty good. According to the spec sheets I’ve seen it was to take a Champion 7 plug. Well that plug is no longer made. When I inherited it from my father-in-law it had Champion 9 plugs in it which seem to work pretty well. From you old time plug experts, what’s the difference between these plugs?
      #41537
        By my old plug chart, 7 is replaced by D9 and 9 is replaced by D21 Or in other words the numbers in order of heat range (hottest first) are:
        D23
        D21 (old 9)
        D16
        D14
        D10
        D9 (old 7)
        D6
        #41553
        redpackman
          So, if I understand you right, the D9 is a direct replacement of the old Champion 7 plug?
          #41556
            Yes, but I didn’t go the next step and see if they still make them. The wire nut (or possible lack thereof) on the end might be a problem
            #41558
            Ron Devries
              You should be able to still find Champion D9, I think I found them at a Farm Equipment store.
              #41647
              redpackman
                The D9 plugs I have, actually a D9F I believe, does have the wire nuts. so all is well there. Thanks.
                #41648
                JOHN D.
                  The plugs now go by the numbers 509, or 516, etc when ordering. The people at our local auto parts store get confused if you ask for a D-9, or a D-16 plug now.
                  #41722
                  wiscoboater
                    The folks at my local auto parts store get confused no matter what plugs I ask for. I gave up with those "cross referencing" kids working the counter. I just order from club vendors now.
