Home › Forum › Ask A Member › Champion 2J 4.2 hp mag / throttle setting
  • #6846
      Is the general rule on syncing "throttle to magneto"
      that when mag is on "Start", the throttle should
      just start to open?
      Will the engine be hard to start if the throttle plate
      is off it’s seat when the mag is on "start" ?
      Right now, in order to have the throttle go wide open
      at mag "Fast" position, the throttle starts to open
      half way between "Slow and Start"
      Thanks!
        What you have now sounds about right to me.
        Remember your motor is always in gear. Having
        a load on it your going to need some throttle
        to get it to cold start. If you could take it out of
        gear the throttle plate would only need to be just
        off idle for starting IMO.
        #56692
          Tubs, thanks for the reply.
          Got the L.U. back on a little while
          ago, so about ready to give her a try
          in the test tank….. may yet today, but
          the weather can’t make it’s mind up
          between rain and snow 😕
