Home › Forum › Ask A Member › CD 18 -F winter project
  • #271223
      bummer… trying to locate my pressure tester but may have left it at the cottage….:-(
      meantime I refilled the GC  and   put a  DOLLAR STORE   “doggie poop    training   pad”  under the  GC … I use them for spills and stains from reaching the floor  being leak proof and all
      for  GC seal kits try  vintageoutboard.com
      Johnson Evinrude outboard impellers, seals, lower unit kits, water pump kits, gaskets – VintageOutboard.com
      • This reply was modified 3 years, 9 months ago by JACQUES.
      #271233
        Funny about the doggie training pads. Did you ever house-break em?
        There use to be a guy at work that drove an old Harley Davidson,
        which leaked a little oil.
        Guys would sneak out to the parking lot and put pads under it
        to piss him off and get a laugh.
          here is the PH and exhaust  ….to be cleaned up
          splines are fine … impeller check next    GC is weeping  some oil on the GC joint so a reseal may be in sight  🙁
