Home › Forum › Ask A Member › CD12 – part# 303696? UPDATE – Found It!
  • #284200
    John Gragg
      Hello all,
      Somehow I lost part# 67 on the attached drawing. Part# 303696.
      It’s the pin that puts tension on the collar plate and spacer when the collar screw is tightened.
      Does anyone have a parts motor that they would be willing to part with this pin?
      Or, some really good measurements and I can hack up an aluminum bolt into a correct sized pin? Nope, no lathe. Just a grinding wheel, some hand files and a sincere desire to succeed! Lol.
      Thx in advance if anyone can help. Hit me up with your price and I’ll send you my info and $$.
      Thx
      Best Regards
      John Gragg
      RIverside, CA
      Just starting in the hobby, please be patient.
      48 Sea King 5hp GG9014A. Sold
      49 Sea King 5hp GG9014A
      48 Johnson TD20. Sold
      49 Johnson TD20. Sold
      54 Johnson QD15. Sold
      55 Johnson CD12. Sold
      57 Johnson RJE-19M
      57 Johnson RDE-19
      #284204
      CHUCK
        https://www.ebay.com/sch/i.html?_nkw=185688221096
        #284205
          You are mistaken, that is not its purpose.  It simply keeps the liner from rotating when steering back and forth.  Any ol’ pin, rivet, screw, whatever, will do.
          #284208
          John Gragg
            Ok – Thanks –
            So the small end of the pin fits into the recessed hole opposite the tiny ‘tit’ hole?
            The drawing led me to a different conclusion, (and the fact that I never even laid eyes on the dang thing, for all I know it was never even there…).
            Thanks !
            Best Regards,
            John Gragg
            RIverside, CA
            57 Johnson RJE-19M
            57 Johnson RDE-19
            #284210
              Yeah, I recon.  The pin head will be in the hole in the split of the liner.  The other hole in the liner will align with the “tit” hole (grease / zerk fitting) to allow grease to pass through to the pivot pin.  Interesting description, tit.
              liner
              #284213
                grind down a  fat nail or brass bolt   whatever  works !
                #284217
                John Gragg
                  Yea, I’m gonna take a stab at it tomorrow. Now that I have the info from Frank it shouldn’t be too hard to make up something that works.
                  John Gragg
                  RIverside, CA
                  57 Johnson RJE-19M
                  57 Johnson RDE-19
                  #284224
                  John Gragg
                    Amazing what happens when you do the chores. In the kitchen this morning, which is where I did a little de-greasing of parts the other day, when I needed to run the garbage disposal (for the 4th or 5th time since I lost this pin). Heard a little clanking and found the pin! Note: I had already checked a few times, but I guess it was hiding and since it is aluminum my magnet did not pick it up.
                    So, here it is. I have already cleaned it up a bit and taken the roughest edges off of it, so it should be good. I did order one that SeaKaye found for me on Ebay, so I’ll probably wait for that one and keep this one as my spare. Worried that if my edges are still too rough I might mess up the piece that this holds in place.
                    Pics are junk, sorry. I don’t know how to delete and start over. No biggie.
                    Just an update.
                    Thanks to all
                    Best Regards,
                    John Gragg
                    RIverside, CA
                    57 Johnson RJE-19M
                    57 Johnson RDE-19
                    #284229
                    John Gragg
                      Pics again
                      John Gragg
                      RIverside, CA
                      57 Johnson RJE-19M
                      57 Johnson RDE-19
                      #284246
                        In the garbage disposal in kitchen??!!?  Wow, If I did that, I wouldn’t even have a kitchen anymore after the divorce.
