Home › Forum › Ask A Member › Cd11 tricky hose routing…
  • #308968
      Converting a CD11 to pump using the plugged channel  method behind the carb plate. Routing hoses to a side pump on the shifter side  is kind of tricky using 5/16 hoses. any special trick ??
      #308980
        When I converted my CD-11, I used Tygon tubing for the air and fuel lines due to the tight spacing.   Here’s one pic I have of the routing under the carb.
        1982 Evinrude 25hp
        #308983
          sounds good .. i’ll find some yellow tubing   thanks      p.s. crazy prices !!!
          #309050
            And btw, that should be 3/16″ tubing for your CD-11.
            1982 Evinrude 25hp
            #309057
              The air pressure pulse nipple  and carb inlet probably  but my round mikuni pump barbs are 5/16 barbs  like my cheapo* amazon side connector.  found some blue  fuel  line  in my kit box  looks like  .25  it does fit th carb and pressure barbs  but i’ll have to mcgiver them into 5/16 pump side. .
              the main  fuel hose (side connector to pump in) is rubber  5/16 and fits  ok
              so I have  2  lines to mate  (pulse and  fuel out)  to the pump barbs  I’ll figure something out or  sand  down the rims on the pump  barbs down to .25 (4/16)
              • notice the rounded  base is backwards  for a CD   Ii needed to square off the round end to flip it over and  round out the  square end !
              thanks
              #309511
                I used an adapter fitting for the 5/16 incoming fuel connection to the 3/16 Tygon hose feeding the pump.   Works fine.
                1982 Evinrude 25hp
                #309514
                  ok tanks i’ll check locally if I can find those… if not i’ll try amazon
                  I noticed how you bolted up the side connector using the   hole just  rear of the oblong base  which would  have made my cheapo adapter fit better and right side up. 🙂
                  it never dawned on me to use  the 2  little humps to support it laterally 🙁  Duh….
                  must be a sexual thing !side-connector
                  #309532
                  CHUCK
                    For whatever reason I never see these adapters available in stores.  They come in handy every once in a while and they are available in all the common combinations.
                    #309562
                      I guess I never paid any attention to it before, but on my CD-11 that fuel hose connector cutout is oriented backwards (like yours) from all my other 1950s OMC motors.   Our CD-11 motors have the semi-circular side of the cutout oriented forward while my other Johnson and Evinrude motors have the semi-circular side oriented toward the rear and the square side facing forward.   I now vaguely recall that was why I mounted the fuel connector between the 2 lugs.
                      1982 Evinrude 25hp
                      #310195
                        got me some adapters as you suggested !  🙂
                        I should able to post some pics soon .   I need to move the pump over a bit but  it  should be all good.
                        nothing new  under the sun here mind you ..just pics of a winter project. if everything works out i’ll probably sell it later on this summer .
