Home › Forum › Ask A Member › CD-?? Engine cowl
- This topic has 19 replies, 9 voices, and was last updated 10 years, 1 month ago by
david-bartlett.
September 20, 2016 at 10:05 pm #44417
September 20, 2016 at 11:55 pm #44424Steve, I could certainly be wrong here, but yours looks to be a darker shade of green than the original CD-10 thru 12. I’m thinking it has been painted at some point too.
-BenOldJohnnyRude on YouTube
September 21, 2016 at 12:01 am #44425Steve,
That is a very old restoration, but not original.
September 21, 2016 at 12:20 am #44427Kyle,
In your case, you have to combine paint combos, and decals, to get the whole story.
Your first picture shown is a 1954 cowl. In ’54, they had the silver trim, with wing nuts. Looking at starboard side of cowl, in the bottom left corner, they had the Sea Horse picture on top, with the "Sea Horse" script BENEATH the picture, and then the 5 1/2 number beneath that. ON the front of the cowl, beneath the rope start, the ’54 either has a Sea Horse picture, with "Sea Horse" script, OR they have starting instructions. Im not sure on difference there sorry but have seen both.
Your second picture shown is a 1955 cowl. In ’55, they had the white trim. In the bottom, left corner of the cowl you can see the "5 1/2 number with "Sea Horse" script underneath it, NOT on TOP of it. That also gives it away, as does the fact that there is NO Sea Horse picture, just the script and number. On the front of the ’55 cowl, beneath the rope start, they have the picture of the Sea Horse, with the number 5 1/2 overlayed on it. NO SCRIPT on the ’55 front.
Hope this sort of helps. I can email you some pictures from original brochures if you want.
September 21, 2016 at 12:22 am #44428September 21, 2016 at 12:34 am #44431September 22, 2016 at 1:38 am #44487Chris P; I have those same ads you do. Thought I had this all figured out, but guess not? Sorry Kyle guess the answer from my perspective is Im not sure.
I also noted in the ads the old which is correct for low speed needle knob? Round or lever? I have seen this for years on CD & QD models. The low speed round knob never looked right to me before as a round knob with a high speed lever. (I call it a lever because I can’t think of anything else proper to call it?) The ads show ’54 vs ’55 the way it should be "I guess"! Still looks weird to me. At least it explains why you see so many with what appears to be wrong knobs that don’t match. I hope someone else can be more precise Kyle.Dan in TN
September 22, 2016 at 2:33 am #44491Wedgies pictures show the uncommon ’55 cover with the thumbscrews on the sides.
These are few and far between.
September 22, 2016 at 10:06 am #44505Yep, the thumb screws were eliminated after the 1955 model cd-12 started production. The first cd-12’s did have thumb screws.
September 22, 2016 at 10:59 am #44510Wedgie’s motor is a Canadian model as well. That could be a factor.
