Home › Forum › Ask A Member › CD Base gasket …orientation issue
  • #273295
      Well I used the new  gasket  (curvy one  to draw out & for  making  the lower  gasket to seal off the water from the lower oil chamber of the GC .
      The  parts listing does not show a gasket  for the underside of the “old style  impeller housing”…being just water anyway
      hopefully my home made  (beige) gasket  will suffice
      #273311
        should be fine, just be sure to use some sealer, those mating surfaces are very thin.
