Home › Forum › Ask A Member › CD 22 kills when shifting into reverse
  • #7029
    skanders01
      About to effect repairs on a relative’s motor. Issue they say is "it dies when shifting into reverse." They did have a clutch dog replaced in 2014 when "it wouldn’t shift into reverse."
      Before I take the gearcase apart, any other less invasive things to look at? I’m not forgetting a failed safety switch or linkage or something else am I?
      Thanks for any advice.
      Kyle
      Kyle Anderson
      Trempeleau, WI
      skanders@triwest.net
      920-764-0501
      #57805
      chinewalker
        My first thought was the shock absorber in the lower unit. It is effectively the bottom portion of the driveshaft, located under the water pump base. They have a habit of breaking and expanding, binding things up under load.
        #57809
          I guess we all jump to that conclusion. But hey you would think that would be more likely to happen when shifting into forward. I’d say it is tear-down time. Look for stuff like worn or tight bushings
          #57810
            It might have fishing line wrapped around the prop shaft and it turns into a big knot when going in reverse. Pull the prop and have a look before doing anything drastic.
              Ah yes, how often we don’t think of the simple stuff.
              #57846
                Never overlook the simple stuff, a lesson I must keep relearning!
