Home › Forum › Ask A Member › CD 17 1960 5.5HP Question
  • #7155
    joesnuffy
      I am working on a 5.5hp CD 17 it was on a small aluminum fishing boat I obtained last year by trading a 18hp twin for it. I have never worked on one and I have a few questions. I don’t know what the heck is going on with the top seal on crankshaft possibly someone here can look at the pics and figure it out. I am unfamiliar with the top seal on this motor and can’t really figure out looking at marine engines schematic. Looks like it was hammered in there somehow.
      I did see that it has a slinger not a seal on the top. I am hoping to get it running it has great compression and new coils so it won’t take much to get it to go I am hoping this won’t stop it from running well.
      Thanks for the help,
      Joe
      #58517
      chas56x
        It looks normal to me. The top "seal" is not really a seal at all, it is an oil slinger. The only way to replace it, if needed, is to split the crankcase, remove the crankshaft and press off and press on a new oil slinger ring. To be honest, I have never replaced one because I have never found one to be bad. As the Brit’s say "Chive on. bloke".
        #58519
          http://boatinfo.no/lib/johnson/manuals/ … on.html#/0
          slinger page 232 233
          Joining AOMCI has priviledges ๐Ÿ™‚
          #58520
            The primer colored area is part of the casting and the slinger is hidden right below it. Perfectly normal.
            #58544
              Oil creeping up the crankshaft is thrown out into a recess in the casting which is drained by a passage leading to the intake manifold. Since there is no metal to metal contact, they NEVER ware out. Failure happens when the passage to the intake manifold is blocked. Cleaning the blockage solves the problem. . . ๐Ÿ˜€
              #58552
              joesnuffy
                Thank you guys so much for the information. I worked on her all day to day. She’s worth saving. I am so glad I found this place. I have learned so much from just reading and I am very a appreciative to all you folks that help us out. Thank you guys so much.
                Joe
                #58564
                Doug Wilson
                  Unless you know the impeller has been replaced recently get a power head gasket and impeller. I have a CD-16 that has had a fairly rough life in our family does not look perfect but starts usually on 1 or 2 pulls even after setting a year.
                  Doug
                  turned off?
                  #58571
                    not certain … but on the 5.5 cd17 you may need to pull the head to change the impeller.
                    looks complicated but isn’t really that hard to do .
                    http://www.youtube.com/watch?v=SVOedhzPP7M
                    http://www.youtube.com/watch?v=EY2HrEdp5vg
                    #58590
                    joesnuffy
                      Shes all back together and running very well. Cleaned the carb, new iginition wires, new fuel lines and clamps, new starter rope etc.
                      Since it was a bit dirty under the magneto and the points were trashed I decided to convert her to electronic modules since I had a couple laying around and thought Ii would give them a whirl. I used a set on my 9.5hp Johnson which allows it to really get down and idle very slow since they fire exactly 180 apart every time. I solder the wires to the modules and keep them as short as possible this allows me to mount them under the magneto plate. I have heard folks here say they haven’t had much luck with the Nova modules but this is the second motor I have put them on and I already had a some so I thought what the heck.
                      I will put a new impeller on her now that I know shes a runner. Very quiet engine I am guessing it was one without roller bearings and has pretty low hours on the power head. I took a pick of my conversion and a couple videos on is without the cowl on when I was fine tuning the carb which was pretty simple on this particular engine. I did put a dab of black silicone under the positive side of the module to make sure it doesn’t accidentally ground itself. She really gets down and idles very slowly.
                      You can’t do the conversion on all motors. Just the ones with 1 set of magnets under the flywheel and weights on the other side opposite the magnets. I have only had success with omc motors 2 cylinders.
                      Thanks for your help guys,
                      Joe ๐Ÿ˜€
                      videos
                      https://youtu.be/XS_WDFt8GZc
                      https://youtu.be/ES5sEK7RYz8
                      #58593
                        Let us know how much time you get out of the Nova II’s. I couldn’t get more than an hour out of them on an early 70’s four horse and one or two only lasted a few seconds.
