Home › Forum › Ask A Member › CD-16 Carb Adjust
  • #4708
    steveh
      Hey Guys,
      Thanks for all the help with the CD-16. She’s back to starting easy and purring like she should.
      I do have a quick question though. The low and high speed carburetor adjust knobs keep moving to the left as the engine vibrates. Eventually, the engine runs rich and bogs down. Is there a nut I missed that tightens these things down? I should I just tape them in place and move on?
      Thanks,
      Steve.
      #39958
      2fast4me
        Packing inside the carb adds friction to the needles just tighten the brass till you get the right tension.
        2Fast4Me
        #39959
        wedgie
          Snug the packing nut up with a 7/16 wrench after getting the needles adjusted, but not too tight as you may need to fine tune them .
          #39960
          david-bartlett
            Yes, just snug up the packing nuts.
            #39961
            fisherman6
              Steve,
              There should be a brass ‘sleeve’ that the adjustment needles fit inside with a hex head on them. Those are the packing nuts and they are there to compress the packing washers into a tapered seat in the carb body around the threaded portion of the needles. Those should be snug enough to prevent vibration from moving the needles out of adjustment at a very minimum. Once the adjustments are close to dialed in, I always snug them up so the knobs do not turn so easily that the adjustments can be easily moved accidentally. I make the final adjustment after they are pretty snug.
              Whenever I rebuild a carb I remove the old packing and clean the pocket out well making sure to get out all the old crumbles of packing. I then replace the packing washers with new ones. The packing prevents unwanted movement of the adjustments as well as air leaking past the needles and leaning out the mixture.
              I hope this helps.
              -Ben
              OldJohnnyRude on YouTube
              #39963
              steveh
                Thanks again guys. I did not rebuild the carburetor, so I’ll snug those down and see what happens. I appreciate it!
                #39971
                  http://boatinfo.no/lib/johnson/manuals/ … hnson.html
                  covers everything on your CD and most oldies
