Home › Forum › Ask A Member › CD-13 ignition arc
  • #17871
    legendre
      @josh
      Yes, it’s possible to arc through a piece of heat-shrink – but not real likely. The voltages are in the 300-400V range (roughly), which should be OK with heat-shrink for a while, at least.
      I’m also a bit surprised that you can hear a little low-energy spark jump over the noise of the motor & exhaust. Are you certain you’re hearing an arc, and not some mechanical collision that’s impairing the ignition?
      #17876
      joshadurham
        Well my best guess is that it’s an arc. It sounds like a small tick noise, and the motor stumbles every time it ticks.
        #17877
        theodore
          I would think if you had a Stevens analyzer, you could hook it up to the engines magneto and run a coil test with the flywheel off. Would be easy to see/hear the arcing.
