Home › Forum › Ask A Member › Carb swap possible?
  • #3214
    philj
      Hello gentlemen,
      A guy I know has a 1963 Gale 5hp (5D22) without carburator. He asks me if I can supply him…
      Could he use one of the following that I already have in my stock:
      1960 Johnson 5.5 carb
      1955 Johnson 5.5 carb
      Thank you for your help…
      #28850
        Well, you would think so, but actually there are enough differences to kill the deal. Mixture needles might be wrong length, and for sure the choke actuating lever is totally different. I think the 5.5 may be a tad larger venturi also. But that probably would only result in getting a tad more power. The jury is still out on that size question.
        adult image sharing
        #28861
        philj
          Thank you… I will wait… 😉
          #28867
          Leon
            You could test your motor with that carb and the cowling off, so you could just see if it runs. Check and see if you can borrow it, so you don’t possibly spend money on a bad motor. Typically, if you get a motor with a carb missing, then it’s likely that the carb went to a "better" motor.
            #28872
            philj
              Hello
              That’s not the situation… The guy who has the Gale without carb is not near me… and it’s not a motor I want to buy… He just asked if I had one fitting his motor…
              #28876
              Leon
                Oops. I did misread it.
                Okay….. be a nice guy take a carb and a six pack over and let him try it. Friends don’t let friends buy carbs for bad motors 😀 😀
                Even getting the correct carb for the motor and finding out the motor is junk, is not a good way to end a day, right?
                #28877
                philj
                  He told me his motor is very good shape, except the carb is missing… it seems he checked everything, compression, magneto, impeller, etc…but he’s far away from me… we’ll see….
                  Anyway thanks for your answer…
                  #28896
                    PhilJ
                    Check with Doug Penn for a used carb. http://penn.itgo.com/
                    Doug is a real good guy to work with.
                    Steve A W
                    #28910
                    Leon
                      Very odd that someone would pull a carb from a nice motor. I hope he finds what he needs and everything works out.
                      #28914
                      philj
                        Thanks t o all of you!!!
