Home › Forum › Ask A Member › Carb Packing ?
  • #2928
    mightymite
      Hello, Anyone have a home made trick for carburetor packing. I just tried teflon tape and that did not work.
      Thanks, John, Member
      #26687
      mr-asa
        The packing for the needle jets? By my experience, everyone is going to tell you to just buy the o-rings.
        You could get a gasket punch kit and knock them out, but it’s not necessarily going to be an accurate punch. I’ve messed around with o-rings, they work well enough for me.
        #26688
        mightymite
          O-Rings ?? OK, I’ll give them a try.
          Thanks, John
          #26689
          mr-asa
            I started a thread where I talked about it. You should be able to search my username and o-rings and find the size
            #26690
            mightymite
              WOW, I put one(O-RING) in and so far I think it will do the trick.
              Thanks again, John
              #26691
              mr-asa
                Glad to have helped. Make sure that the material the o-ring is made of can withstand gasoline and ethanol so you don’t have any issues.
