Home › Forum › Ask A Member › carb kit for evinrude 4423 #00896
  • #285290
    Hiawatha
      anyone know what carb kit for evinrude 4423 #00896?
      thanks dave
      #285291
        1947  4423 .. 3.3hp  . must be similar to a HD  or TD ..?
        you would  need some leather  seals for the primer pump and  a float (Merc floats can be fitted)
        the rest is mostly cleaning   maybe cutting your own gasket     …see poche family site and Johnson  redbook
        Basic Carburetor Servicing Johnson H and T Series (pochefamily.org)
        #285294
        Hiawatha
          gotcha, thank you for your responce, dave
          #285319
          CHUCK
            Serial-Number-Chart_Hunn
            #285323
              see similar listing
              #285348
              David Bartlett
                This carb is nothing like the one on a TD or HD,  Totally different animal. Supposedly the first carb designed using a computer, back in the day. It is unique.  Biggest issue is primer cups are hard to come by.
                Adjustment needle is very blunt, so a little bit of adjustment goes a LONG way. Adjust this one very slowly.
                David Bartlett
                #285353
                  interesting I had no pics of the animal .. I guess Evinrude and Jonson has two masters   the 50-60s  J&E are almost twins 🙂
                  any chance  for pictures ??
                  thanks for the update
