Home › Forum › Ask A Member › carb adjustment for zepher or Lightfour
  • #244534
    jim-moffatt
      has anyone been able to get the low speed carb circuit to work on a Zepher or late Lightfour? I always end up
      with my low speed needle completely closed.
      #244539
        My Zephyrs run and the carbs adjust OK but my Lightfour tends to flood badly on the high speed circuit.
        This diagram mentions seats for the needles but doesn’t show them. I suspect the Lightfours high speed seat has fallen out and now I can’t adjust the fuel flow on it. I sure wish I could find the exploded diagram in my files of the carbs which does show the seats. You might have the same issue.
        Click on the link for the Zephyr carb manual.
        ZephyrCarburetorMaintainance
        49-Zephyr-Tank-and-Carb
        • This reply was modified 5 years, 3 months ago by Mumbles.
        #244600
        jim-moffatt
          If you remove the HS needle you should be able to see the seat with a bright light. I have a PDF of the carb maintenance manual can send it to you if you want.
          • This reply was modified 5 years, 3 months ago by jim-moffatt.
          #244604
          jim-moffatt
            I cant submit the pdf manual it is too big. CAN SEND IT SOMEOTHER WA
            #244607
              PM sent.
              Is this the same manual I included in my previous post?
              #244702
              jim-moffatt
                yes
                #244778
                mercuryman
                  I think the seat is part of carb body, I had that problem someone over tightened the main needle and damaged the seat had to replace carb
                  #244991
                  jim-moffatt
                    On the Lightfour the seats come out but apparantly with great difficulty, mine are OK.
                    #245423
                    jim-moffatt
                      just to close the loop. I got the carb adjusted. I was trying to do two things at once – adjust and make the motor run slow. It can be adjusted at intermediate speeds and then slowly worked down to the slowest. It now runs on the slow speed needle with the throttle completely closed and picks up fine when the throttle is opened.
