Home › Forum › Ask A Member › Capacitors
  • #170871
      Since the Website Change, I cannot seem to search topics anymore? Tried capacitor, condenser, all with no results?
      What am I doing wrong here.
      Regardless, can anyone point me to the discussion in regards to the capacitors that our Members were using. I believe they were 400V?
      Thanks.
      #170873
        Instead of the search bar at the top of the page, use the search bar on the right side where it says “search forums”. You should find what you need there. Don’t know why the one at the top no workee.
        1982 Evinrude 25hp
        • This reply was modified 7 years, 8 months ago by Bob Wight.
        #170940
          Hey Chris, it was Sept 26 2014 when Jeff Register posted about 800 – 850 volt Vishay axial cap part numbers on the old YaBB boards. I did save that post so I may have to snip part of it to post here later.
          In the meantime, here’s links to Digi-Key for the 0.10, 0.15 and .22 uF caps most commonly used in our motors. You can change your country in the top right corner.
          If available locally, Orange Drops will work to.
          https://www.digikey.ca/products/en?x=23&y=19&lang=en&site=ca&KeyWords=bc2607-nd
          https://www.digikey.ca/products/en/capacitors/film-capacitors/62?k=bc2608-nd
          https://www.digikey.ca/product-detail/en/vishay-bc-components/MKP1839422084HQ/BC2609-ND/2260507
          DSC01376
          0.22-uF-Caps
          • This reply was modified 7 years, 8 months ago by Mumbles.
          #170974
            Great thanks Guys!
            #170978
            ADAM GIBB
              I put a Vishay cap in my Johnson A and it runs great!
              #170999
              thumper
                nice
                #171138
                  I should have enough now for a long time!
