Home › Forum › Ask A Member › Capacitor tester box
  • #221707
      The last Outboarder had a good article by William Mohat on how to build a capacitor test box.
      I went ahead and built the simpler version out of the 3 suggested in the article and then proceded to test by “used caps” box contents . All showed failure on the (red) idiot lamp.
      Testing involved voltages around 270 VDC generated from a voltage doubler using a couple of diodes, , .22uf caps , resistors and a main DPDT switch
      I tried a brand new capacitor worried my test box was a bit overly critical … the new capacitor passed the test with 100 % success with the FAIL lamp staying dark.
      The box cost me about 70$ CDN … a lot more than several new caps some would say but it was a fun , easy project to build and I can now be 100% when testing caps
      no more swapping/junking caps for nothing πŸ™‚
      thanks for the article Mr.Mohat
      #221710
        Crosbyman,
        Can you referance the post by William? I’ve had fun with diodes too.
        • This reply was modified 5 years, 11 months ago by jeff-register.
        #221712
          It was not a post it was a detailled AOMCI “OUTBOARDER” article with circuit layouts for 3 models of the tester.
          #221742
            Thank you Crosbyman!!
            #225738
            olcah
              Crosbyman,
              I assume the Antique Outboarder magazine that you refer to is the October 2020 edition. Bill Mohat discusses condenser testers on pages 40 and 41 but darned if I can see the circuit layout for his home built neon tester (or any other). Can you set me straight? Where did you find the circuit layout?
              Thank you.
              #225739
                Actually… if you read real closely, mr. Mowat invites (for safety reasons) able “test box builders” to write him a e-mail so he can send you a PDF file with all 3 designs.
                I built the fix voltage one (approx 275 VDC with a few simple components). The two other models involve a more complex design and a more costly test box..
                The basic model works real well and is recommended by Mr.Mowat . I have already identified a bunch of “presumed good capacitors ” now R.I.P. πŸ™‚
                #225741
                olcah
                  Thanks Crosbyman. I had already requested the PDF from Mr. Mowat but have not got it yet and wondered if I missed something πŸ™‚
                  • This reply was modified 5 years, 10 months ago by olcah.
                  #225743
                    how long ago did you write him ?? he seems fairly busy so give it some time I have waited a few days for replies πŸ™‚
                    sorry for confusion I had wrongly remembered seeing the designs in the Outborder but actually wrote to him to get them .
                    #225749
                      • This reply was modified 5 years, 10 months ago by Tubs.
                      #225754
                      olcah
                        I emailed Mr. Mowat about 3 weeks ago. If I do not hear from him I will try again after New Years. Good to hear that the tester works so well!
