Home › Forum › Ask A Member › SOLVED – Can’t get this RDE-19 out of gear
  • #323514
    Good day folks.
    figured I would ask this in a new thread in case it helps others.
    I have a 1957 RDE-19 with unknown history. I can’t get the motor out of gear.
    I have no controls. Only the side lever for now.
    It’s stuck in forward.
    The propeller does not spin free hand with any effort.  It moves back or forward an inch or so than locks up.
    I have removed the plugs, so it’s compression stopping it.
    I drained the gear oil, and sadly, about a shot glass of pure water came out, followed by very dark green gear oil. Not good.
    Any ideas how to get this out of gear and into neutral?
    I suspect it’s either rusted lower or seized upper.
    Any help sleuthing would be appreciated.
    #323538
      Well, perhaps it is just the vertical neutral lock out bar that rides on the shift lever.  Does it move back and forth freely?  The throttle has to be retarded in order to shift the gears.
      My next suggestion would be to remove the gearcase in an effort to determine whether the gearcase linkage is stuck/damaged, or the shift linkage on the engine is jammed up.  Sounds like the gearcase needs to be pressure tested to determine the source of the water leak anyway..
      #323547
      MIKE SIMS
        What Don said. And
        I had a motor that the gear #6 in the pic was seized on bushing #7 (old dried up grease)
        304814
        #323549
        scratcher
          Open the little oblong cover with two screws on the lower unit side.  Unbolt whichever bolt you can see holding the shift rod upper to the lower shift rod.  This has to be done before you drop the gear case. You will also be able to tell if the gear case is frozen up if you can now move the shift lever.  If you only got a shot glass of water it’s probably not rusted solid. There should be a little dial with pointer where the throttle grip/tiller would attach if this motor was set up for remote controls.  Turn that to where it is marked slow before trying to move shift lever. Also if you can’t budge the flywheel the slightest amount right now then the motor is frozen.  A lot of times that breaks free when you try to take off the flywheel so take the sparkplugs out and dump some oil or spray some penetrant before trying to turn it to minimize scoring because the cylinders are likely dry. You may know all this already I’m just rambling….
          #323552
          SOLVED:
          My motor was set to “start” so I moved it to slow and voila. Moves it and out of gear as it should now!
          You guys are great.
          #323578
            SOLVED:
            You guys are great.
            Cool!  Glad it worked out easily
            #323579
              SOLVED:
              You guys are great.
              Keep in mind, you can’t always shift it into gear statically without spinning the propeller to align the gear/dog lugs properly.  You should be able to take it out of gear no problem though
