Home › Forum › Ask A Member › Cannot Identify Vintage Stern Brackets
  • #6195
    bobbyg
      Need help identifying a couple of old stern brackets (numbers: 700182RH & 700183LH).
        No visible tilt adjustment – Trolling motor?
        #51807
        chinewalker
          Look kind of Clinton-esque.
          #51860
          bobbyg
            The basic shape looks identical. I looked at other Clinton lower end bracketing and their stern brackets all have that additional section which appears to lock the motor in a specific attitude. If mine is a Clinton bracket, it probably just doesn’t have that added feature. Thank you. Well done.
            #51862
              Looks like the tilt adjustment part has been ground off (??) That’s odd.
              #51868
              JOSEPH BRINCAT
                Tilts ground off… perhaps were going to be used for some arrangement of a transom clamp wheeled dolly or a car roof top loading rig.
                #51888
                ADAM GIBB
                  Eska-esque….LOL
                  #51902
                    I thought that would be a good way to put temporary lights on your boat trailer. Attach them to the boat. Wrap up the wiring and put it in the trunk of the car when not in use. . . 😆
                    #51916
                    retiredoz
                      Looks like it had some kind of tap-in pivot bolt. Clinton/Eska/just about everybody I can think of used a standard-issue carriage bolt ?
                      #51917
                      retiredoz
                        Or maybe my eyesight is worse than I thought…
