Home › Forum › Ask A Member › Can someone help me identify what Motor this is
  • #7895
    bewa2929
      I aquired this motor in a trade the best I can tell is that it is a Martin. I don’t know what model it is I suspect a 20, 40 or 60. I can’t find a serial number, can anyone tell me where to look. Thanks!
      ryanjames170
        Any sort of SN on it
        #63014
        jpatti75
          Based on the leg, I believe you’ve got a Martin 60 there.
          JP
          #63015
          johnyrude200
            +1 on a Martin. You can see the logo on the side of the motor. Black paint with the white martin logo.
            #63017
              Look like this at one time.
              Picture is from the internet.
              #63036
              bewa2929
                Thanks I can’t seem to did a serial number where are those located in these motors?
                #63037
                ryanjames170
                  quote bwallen36:
                  i think IIRC both on the cowl and on the block but u can contact Russl from https://martinoutboards.com/ he should be able to help you figure it out as u will need to know for parts as there are some variants in engine parts evan on the same HP
                  #63062
                  JOHN D.
                    It’s a Martin 60 but a later one. That second anti ventilation plate on the motor leg came out in 1949-1950? Usually there is an id plate located on the tiller.
