Home › Forum › Ask A Member › Can rewind springs be fixed
- This topic has 7 replies, 6 voices, and was last updated 4 years, 11 months ago by
JOHN HOLBIK.
December 2, 2021 at 8:57 am #250558
Any experience3Suggestions fixing rewind sprind . ??
I have a 4hp Merc which will likely need a spring (TBD) …..any chance the broken en loops can be reshapped and annealed after bendng back in shape ??
December 2, 2021 at 9:16 am #250559
You can heat the spring red and put a loop in the end.
It will then be “annealed” . You want to try to make it
hard again so while it is still red drop it in oil if possible
but water will work. Hard to say how long it will last
but if you can’t get a replacement your options are limited.
TubsA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 4 years, 11 months ago by
Tubs.
December 2, 2021 at 9:16 am #250560get a new one they are cheap. it will only break again if repaired
December 2, 2021 at 9:54 am #250563Cheap is relative …in Canada not always so cheap. π knees, hips and bypass are free… that is cheap! π
December 2, 2021 at 11:43 am #250569As a kid ( 10 years old or so ) i remember going to the dump with my grandfather and coming back with old tractors and go carts most had broken recoils many times i tried to ( fix ) a spring by reshaping the ends but it was temporary at best
hondaatc.
December 2, 2021 at 12:27 pm #250571ho well… to bad i’ll see more when I pop the Merc 4hp recoil open in the coming weeks along with a couple of 4hp and a CD to prep fpr Spring time π
December 2, 2021 at 7:50 pm #250588My two cents on this rewind spring deal. You need to make sure that the rope hits it end before the spring hits it’s end! Some times the spring tension is set too tight and it bottoms out it will break again new or old. I have made snowmobile springs work in outboard motors. I also have bought new springs that were to short. I wish I had a nickle for every one I have had apart. The center hub should not turn. Get the right size rope and the rewind needs to work free and easy on the bench before you ever put it to work!
dale
get’em wet….don’t let’em set!
December 5, 2021 at 2:08 am #250692Years ago I fixed lots of OMC ones.We did not have Hydro so would heat the end on the propane stove bend the end and drill out the eye from the broken piece with a breast drill re rivit it and off we go. Biggest cause of failure is too short a rope or pulling the cord to the end of its travel.
