Home › Forum › Ask A Member › Can I rig a kill switch on a 1949 ELTO Sportster?
  • #5478
    paulfromyork
      I have a1949 Elto Sportster, which is running very well, thanks to all the help. Thank you. I thought there was a kill/ground wire on the throttle rig, but if it ever was there, it’s not working now. Can I rig a kill switch on this twin. I know it would be easy on a one lung motor. But if I put a wire on each plug through one switch, won’t that interfere with having the spark only at the correct cylinder at the correct time?
      #45674
        Run a single wire from each breaker point to a door bell switch mounted on the cover. Pushing the button shorts the two together. That kills the ignition because each breaker shorts out the other. It’s like the points never open. . . 🙂
        #45675
          OR – you could use the more expensive (and water proof) OMC stop switch.
          #45679
          ROBERT LAFAYETTE
            The Great guys @ the Pinetree club made an awesome Youtube video on how to do this (Thanks Pinetree Club) 😎
            https://www.youtube.com/watch?v=CZi70o1PiIo
