Home › Forum › Ask A Member › Can anybody share specs/parts list for 1947 Elgin 5.5 hp model 571.58601
  • #189634
    seahuntboater
      Greetings. Thanks to Bob for helping me identify my new project motor. It would be so helpful to get some information/documentation so I don’t mess it up.
      I would suspect it was manufactured by West Bend. Carb is MD4
      Thanks . Ralph
      #189645
      CHUCK
        Deleted. Wrong info
        • This reply was modified 6 years, 10 months ago by CHUCK.
        #189671
        seahuntboater
          Darn, I felt like a kid in a candy store when I saw that I had a new reply. Hopefully somebody will have something. I want to figure out where to put the lubriplate and how to check the impeller and it does not look that obvious.
          #189678
            The lubrication is easy. Still looking for info on the water pump. I’m thinking it may have the old sliding vane pump.
            elgin-lubr
            #189684
              Does your motor have the 125536-1 clip at the lower front of the motor leg? If it does snap it off to access the nut holding the gearcase on. There will be another not or screw aft of that, coming up from below. No clip??? Then things are tougher.
              Picture shows the rubber impeller.
              Elgin-Motor-leg
              #189688
                This is NOT your motor. Postiing it for reference only. If your motor does not have the clip mentioned above, then the forward gearcase stud goes way up to below the steering pivot king pin and is held by a special nut, which requires removing the powerhead, then pulling the king pin out. Now you can access that special nut, which requires a special screwdriver.
                Note: if you have this kind and the sliding vane pump, I suggest leaving it alone till you get it running. If it pumps water at idle speed, the vane is ok. If it doesn’t pump, or doesn’t pump at idle, the pump requires attention. The ends would wear on the sliding vane, and the first indication is no pumping at idle.
                11.-Stern-Bracket-and-Motor-Leg
                #189696
                seahuntboater
                  thanks. I will post a close up picture or two tomorrow. I definitely do not have the clip style. I will work on the grease first and then when running hope for good water flow.
                  #189864
                  seahuntboater
                    Here are a few pictures. I only see one screw. what is that one for? Where to add lube?
