Home › Forum › Ask A Member › can anybody id this tool?
  • #1011
    opposedtwin
      it was with a bunch of outboard parts I came across. I imagine it’s a puller of some sort. anybody know for sure?
      #12664
      mr-asa
        Looks like it would expand something. That screw would interfere with the jaws as it was tightened which would spread them out.
        #12666
          It could quite possibly be a flywheel and/or carrier puller of some sort. ❓
          #12667
            I think it goes with a slide hammer. Used for pulling Seals and outer bearing races …
            #12669
            mr-asa
              I think Garry wins again.
              #12670
                It’s part of a set for installing and removing upper gearcase bearings.
                http://boatinfo.no/lib/evinrude/manuals … e_h336.swf
                #12671
                DAN ANDERSON
                  Per the ’76 special tool catalog the #380657 (which can be seen in the pic) is used with slide hammer #380657 to remove propeller shaft bearing cup on 1974-76 9.9 & 15 hp models. Also removes bearing assy #379503 & needle bearing assy #379505 from 1966-68 100 hp outboard gearcases. Also used on stern drives with same applicable gearcases. That’s straight from the book.
                  I have used mine for all kinds of other stuff. It will pull almost any seal you can stuff it into. I have another one I have modified so it goes into a smaller hole. Neat all around tool.
                  Dan in TN
