Home › Forum › Ask A Member › Caille model 16 rings
  • #6286
    lyks2tinkr
      I’m putting my model 16 back together after sitting in a
      box for 3 years. Although it looked decent the internals
      were a mess. I located a decrepit parts motor with blown
      cylinders but the crankcase was in great shape with
      little play anywhere,all original.
      When I took a look the rings are butt cut and no
      locating pins. 1st time I’ve run into that.
      Even though the original rings were pretty decent I put
      in a new set of rings with tighter but in spec end gaps.
      Got nice rings from Hastings,very consistent tolerances.
      Hastings recommends .0035 end clearance per inch of
      bore.
      The gap is .008 to .010 at the bottom of the bore and
      .012 to .014 at the top of the bore.
      Since this is the first time I’ve run into this type of
      ring arrangement is there anything I need to be concern
      with?
      Phil T Yankee AOMCI
      #52615
        Sent you a PM.
