Home › Forum › Ask A Member › Buzz Box–1919 Evinrude Row Boat Motor–Key West, Fl.
  • #54347
    keywestbob
      Richard—thanks a million for the information and photos—I see the smiling face–Sincerely, Bob Watson
      #54363
      keywestbob
        Richard—not sure if you received "MY THANKS’ for the information and photos—Bob
        #54364
        keywestbob
          Hello Richard–I understand all that you wrote and the photos are great but I`m curious how "YOU" attach the green wire from the buzz box (Model-T Coil) to the points–do you wrap the end of the green wire just around one of the screws on the shut off button–or—do you use an alligator clip–or–do you attach the green wire to the points some other way? Sorry, this is my first time. Would you have a photo of how "YOU" attach the wire? Different people tell me different things—I trust what you tell me–Sincerely, Bob Watson–email: bwkeywest@comcast.net phone: 305 292 4821
          #54367
          RICHARD A. WHITE
            I have that switch inline so I can kill the motor by pushing down on that switch.
            The wire is attached to the switch by inserting the wire into an opening on the switch and then tightening a screw that acts as a clamp to hold the wire.
            Alligator clip on the motor end of that green wire connects to the screw I pointed out in my picture.
            3 options….
            1: solder the wire directly to the box.
            2: they have these clips, don’t remember what they are called, solder the clip to the box then insert the wire into the clip. but I can add a pic of one tonight.
            3: or solder a screw to the buzz box and use a wire ring terminal to attach the wire
            They are found at Steam and Gas shows, around here… My other box has those clips on them.
            classicomctools@gmail.com
            #54370
            keywestbob
              Richard—OKAY—got it–you don`t have to send a photo–I also have a shut off switch –in line–on the green wire –plus an alligator clip to attach to the adjustable screw which is one side of the points–the adjustable screw is insulated from the motor–thanks again–Bob Watson
