Home › Forum › Ask A Member › Brought home a Ruddertwin
  • #5911
    Tom
      This has been hanging on the wall at my local dealer for years. He’s retiring and cleaning out so now it’s my turn to hang it on the wall. I’d like to run it but it’s missing a carburetor and advance lever. It turns over nice and seems to have good compression. There is also no ID tag on the front. I would like to find the correct year if anyone can ID it and If anyone might have the correct carb and lever that would be great. Thanks for your help! Tom
        Would A little more detail help? . . . 😀
        1924 ?
        #49303
          That lever is the the main part of the Atwater Kent Ignition system. Missing Ignition AND carboration – Any grease in the lower unit?
          . . . . . . GOOD LUCK .
          #49323
            There is a good chance that
            Doug Penn could have the parts
            you need but he is spending the
            winter in Florida and wont be
            returning home to April. If you
            don’t have any luck getting what
            you need by then you can contact
            him.
            Here is a link.
            http://penn.itgo.com/
            You may also find these useful.
            https://www.youtube.com/watch?v=zLS6IglCy9k
            https://www.youtube.com/watch?v=pFelCQwciSk
            https://www.youtube.com/watch?v=e2vxDqF_OEU
            #49330
            Tom
              Excellent! I’ll post more pictures as I dig into it. Thanks so much! Tom
              #49333
              Goman
                I believe American Outboard sells an ID plate for them if you go the restoration route. Not sure what or if you would put in the model or serial number section.
                #49350
                hotrod
                  Look under the starboard cylinder, on the crankcase, for a possible serial number stamping there. My 1923 has the sn stamped there. Most ruddertwins don’t though.
                  #49354
                  WAYNE
                    It looks very much like my 1924 Model C. Post lots of photos as you take it apart. I plan to start working on mine soon so your restoration will also help me.
                    Wayne
                    Upper Canada Chapter
                    uccaomci.com
                    #49364
                    Tom
                      Great! Thanks for the information about the ID tag. I am excited about this project. I wish that it had a serial # though. I checked the starboard side crankcase, there is a machined pad but unfortunately no stamping on it. The stamping guy must have been on his coffee break when it went by. Ha!
                      OK, Maybe a "1924 Model C" Thanks!
                      I appreciate everyone’s help and great information.
                      Tom
                        I’ve have a 1925 "C" apart and I checked for the
                        S# on the block and couldn’t find one either.
                        I have Super Elto and Evinrude horizontal
                        twins from 28 to 31 and the block is numbered
                        on all of them. Possibly the tag is the only number
                        on these and they didn’t start stamping the
                        block till sometime later.
