Home › Forum › Ask A Member › Broke coil wires on 1936 2.5. 4158
  • #258050
    Donald Keller
      Pic of motor
      16498006054925026670928135680743
      • This reply was modified 4 years, 6 months ago by Mumbles.
      #258053
        Here’s a conversion I did on a similar looking 1940 Elto Evinrude Handitwin
        using OMC universal coils. Runs good.
        Careful planning to see if it’s possible on your motor recommended.
        DSCN1582
        DSCN1602
        #258069
          It seems to be a common coil and was used in a myriad of motors back in the day. A good replacement shouldn’t be too hard to find.
          4158-Coil
          #258094
          JOSEPH BRINCAT
            OK… good, now we are on the right track.  Not to presume, but there is a possibility that Donald can find and attach new spark plug wires to the coil. Do not attempt to “screw” into the coil. Some careful probing may uncover the termination of the very fine secondary winding. Normally that fine copper wire is terminated to a short piece of braded wire or a tab of copper. If you can find that or the actual end of the coil wire, carefully solder an attachment tab, secure and wrap the repair area so that nothing moves.
            Although it would be a good idea to test the continuity of the secondary winding to ensure that it is good, before investing too much time. On this type of coil, test continuity from one spark plug wire lead to the other,, should be about 6,000 to 7, 000 ohms
            #258099
            Donald Keller
              4158-Coil
              Thank you for pic and information ,was wondering what you used on your motor for the white contac
              #258101
              Donald Keller
                Thank you all for the pics and information..I am very excited to work on this motor now and I have hope of getting it going now with your alls information and advice.I will give an update when I make some progress.I appreciate everyone of you
                #258108
                JOSEPH BRINCAT
                  He asked … “was wondering what you used on your motor for the white contac”
                  I’m guessing that you are asking about the white capacitor that shows on Bucc’s motor… Looks like a modern foil capacitor?
                  #258109
                    Yes, modern electronic capacitor from DigiKey, not sure what mfd was used.
                    #258114
                      A 4158 model is a 1936 2.5 horse Handitwin and the capacitor (condenser) for it should be rated at 0.10 uF (microfarads).  These Vishay caps from Digi-Key will work well.
                      https://www.digikey.ca/en/products/detail/vishay-beyschlag-draloric-bc-components/MKP1839410084HQ/2260505?lang=en&s=N4IgTCBcDaIEYGMwDYAMB2AtAOwCYgF0BfIA&site=ca&x=23&y=19
                      #258127
                        Here is another possible solution for you to choose from.
                        You remove the laments from your old coil and resize them
                        to replace the ones in the new coil. Will provide you with
                        more info if you should decide to go this way.
                        https://www.ebay.com/itm/232218550107
