Home › Forum › Ask A Member › British Seagull replacement cdi high tension lead
  • #328578
    GUY SCHMIDT
      How do you replace the high tension lead in the cdi models of the Seagull? It seems to be epoxied in.
      Before I experiment I’d like to hear from someone who has done it. Nothing worse than an experiment
      gone bad ! I don’t have any shop manuals for this either. The manuals I have are for the older points models
      so if you have this written info I would greatly appreciate it.
      #328580
      Michael Anfossi
        International Member
        If you have the white ignition CDI. the HT lead screws in.  If you have the brown/black one, I do not think they are replaceble
        #328603
        GUY SCHMIDT
          Thank you for that info even though it is not that good. Now, has anyone tried to do the imposable and replace the lead the hard way?
