Home › Forum › Ask A Member › British Seagull condenser and spark plug
  • #264199
    GUY SCHMIDT
      Hello all, I have a 1968 Forty Plus with a Wipac ignition. Where is the condenser?……not like the OMC ignition plate with everything out in the open! Also, they call for a D16 Champion which I don’t have new but I do have a new D14….will that work?
      #264200
        Condenser is bult into the coil.  Should be ok with the D-14.
        #264203
        GUY SCHMIDT
          Thanks for that info……..can you check the condenser some how, and how does the D14 differ from the D16?
          #264214
            If I were a gambling man, I’d lay odds that the condenser is fine.  One thing that impresses me about those motors is the damn things always run.  Drop it overboard, fish it out, drain the water out, maybe a couple of shots of WD-40 and it just keeps going.
            D-14 is a bit cooler plug.
            • This reply was modified 4 years, 2 months ago by frankr.
            #264232
            rmhxruss
              Champion D21 . from memory.
              #264241
                Takes a 1278 (D16)   Item 28
                British Seagull Outboard Spark Plugs – Sheridan Marine
                Sea-Gull-
                #264592
                Jean-Francois TRAINI
                  International Member
                  You can also use NGK A 6
