Home › Forum › Ask A Member › British Seagull
  • #260822
    David Jenkins
      Just picked up a British Seagull #SJPL  122C in very good shape and running.  Questions are, can someone help me identify the make and year?  Also, Where would I go to get a vintage decal for this motor?
      Thanks!
      #260833
      Monte NZ
        Hi David
        The website “Saving old Seagulls” will have all the info you are after
        and should be able to provide info where to get a vintage decal.
        Monte NZ
        #260841
        David Jenkins
          Thank you!
          #260843
            The two British Seagulls I’ve owned used a 10:1 fuel mix and required hard to find 140W oil in the gearbox, or a home brewed mixture of grease and oil I would cook up to resemble 140W.  Mind you, these were the larger Silver Century Plus models with a clutch and the smaller motors might use regular 80-90 gear oil. Not sure. I think the newer models went to 25:1 mix to. Also, if they don’t leak out of the crankcase joint, something’s wrong!
            Here’s a link to the Seagull site:
            http://www.saving-old-seagulls.co.uk/index.html
            #260846
            David Jenkins
              Great info!  Thanks!
