Home › Forum › Ask A Member › British Seagull
  • #190199
    1948-goodyear
      I just picked up a British Seagull WS124301.Would this engine be a 1974 4hp?
      #190200
      CHUCK
        Lots of Information here:
        http://www.saving-old-seagulls.co.uk/index.html
        ws
        More information here:
        http://www.britishseagullparts.com/identification.htm#Silver-Century
        ws2
        • This reply was modified 6 years, 10 months ago by CHUCK.
        #190212
        1948-goodyear
          I had looked at the charts but they are a little hard to get the exact year & HP. I think it’s a 1974 4HP but I was just checking to see if there would be a different chart to go by.
          #190229
          rmhxruss
            The serial numbers have a code in them. Need to find my chart.
            #191238
            ausf233
              Easiest way is to use the Seagull Engine Identifier.
              Go to http://www.saving-old-seagulls.co.uk
              Click on “British Seagull Engine Identifier”
              Enter your Serial Number
              Hit return and you should get this;
              WS124301
              Unfortunately in this case, the manufacture date does not appear. However in most cases, the month and year of manufacture are clearly advised.
              Might be worth double-checking that serial number and trying again.
              Hope the above helps.
              Regards,
              Spiro
