Home › Forum › Ask A Member › brain fog . gasket orientation
- This topic has 12 replies, 5 voices, and was last updated 3 years, 8 months ago by
JACQUES.
February 26, 2023 at 2:28 pm #273187
trying to use the “new pump kit” gasket for a 5.5hp CD but the new gasket if oriented to match the curvy part of the base will block the water channel from the GC …
I am cutting spare ones from gasket paper using the new gasket design but… for some reason doesn’t feel right
Has anyone tried using the new curvy looking gasket pattern under the original pump body on a Cd 18
my old pump body looks fine but I am just trying to cut myself some ” cheap ” gaskets to go under the pump’s lower plate where the oil seal fits in
like I said… just brain fog
February 26, 2023 at 2:29 pm #273188jpg ..second try !!!
February 26, 2023 at 4:36 pm #273195edit… again
notice the original gasket in the parts diagram vs the new style orange gasket … where the curvy loop is it will line up with the upcoming water channel but…. the curvy loop does not link up to the main gasket to form a complete circle to seal off the oil from the GC . ?? AM I wrong ?
I will cut new gaskets leave the curvy loop section but close off the missing ling to the main gasket body see next edit ….
February 26, 2023 at 4:46 pm #273196edit… again
February 26, 2023 at 4:46 pm #273197JPG poofed again !!!
February 26, 2023 at 5:07 pm #273207OK, well that orange gasket pictured is for the new style plastic hsg/SS liner water pump, this gasket fits between the plastic impeller hsg and the SS impeller plate. That gasket should not be used in between the upper bushing seal housing and gearcase hsg. The original gasket 303339 is still used and has not been superceded.
All that being said, I am often frustrated by the design of the 303339 gasket that is sandwiched between the upper bushing/seal hsg and gearcase. Why the heck is the OD cut back like that! Doesn’t make any sense, and makes it super hard to seal that area properly. Anyone that wants to reproduce these gaskets properly with the OD of the gasket covering the complete mating flange of the gear housing will get financial support from me and an order for 100 of them!
February 26, 2023 at 6:28 pm #273213February 26, 2023 at 6:41 pm #273215Here’s a pic showing the gasket over the impeller wear plate.
"Every time you remove a broken or seized bolt an angel gets his wings."February 26, 2023 at 8:15 pm #273218feel so brain silly now…
thanks for the gust of wind it is all clear now. (No instructions came with the “new kit”)
As to sealing the “underside” with a 303339 copy, I’ll be using the curvy gasket as a model while leaving in the ” missing link” of the curve. This will surely seal off the oily section from it’s the impeller water routing duties .
1/32 inch home made gasket paper should be fine but can’t vouch for results till Spring time …
no reason why it would not work since the modified copied…curvy gasket as how in quote # 273197 becomes a look a- like to a 303399. I’ll make certain the GC water channel lines up.
Problem solved …:-) I,ll post pictures asap… Casino day tomorrow 🙁 can’t work on my CD .
Big thanks to everyone 🙂
February 27, 2023 at 8:27 am #273227feel so brain silly now…
I’m assuming the water pump kit you bought was not on OEM/OMC/BRP kit.
What I think I’m hearing you say is that you modified the new style impeller hsg gasket so it fit/sealed properly over the water passage on the underside of the upper bushing/seal hsg? Am I hearing you correctly? If so, I may have to investigate this substitution/modification to resolve a frustrating issue! Let me know, thanks. Don
